My truck / one moretry -
04.23.2006, 07:18 PM
04.23.2006, 07:20 PM
I think it did!!!!!!!!!!!!!!!!!!!!!!!!!! A lot more work needs to be done on it...but it still is fun. Haven't totally got it complete and runnin yet. Still need screws that will fit the strobe. 4-40's DO NOT work, but i think i know which to use.....3mm's should. Also still need a ubec...
04.23.2006, 07:25 PM
I can't see the pic cause it say I am not a member.
04.23.2006, 08:43 PM
Same here, it doesnt work.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
04.23.2006, 10:10 PM
sign up page here aswell
04.23.2006, 10:13 PM
darn, need to make them public...i'll get it in awhile...sorry.
04.23.2006, 10:29 PM
try this... emaxx.livedigital.com
04.23.2006, 10:32 PM
04.24.2006, 07:50 AM
It works now! Nice truck! Very neat wiring!
Losi 8ight e
Hyper 7 Erevo Center Diff
04.24.2006, 08:13 AM
looks good, but here's a suggestion......you should switch the bl controller with the receiver.....this will cut down on wire length ect.....but overal it looks great....good.. job
04.24.2006, 09:29 AM
Thanks guys. How do like the mod mount job that i used for the controller!!! Does my parrallel look right? it seems two neg wires will be going to one battery? is that correct? I still need a ubec though!
04.24.2006, 09:46 AM
Also, the other question i have is, the wires that go into hte receiver. I'm not sure which ones the neg pos and so forth. i have orange, brown, and red think....so which way does the plug go into the reciever? Can you see it in the pics? Also, i pulled out the black jumper, do i need to do anything else to the controller?
04.24.2006, 09:55 AM
your wires on the esc for the batteries looks correct....just make sure you have them like the following.....from the esc....black wire (-),(+)to(-),(+) red wire to esc......as for your other question....the brown wire should be in the rx the same way your servo wires are...ie...black wire on servo lead.....hope this helps....
04.24.2006, 09:57 AM
i'll check it out. i won't need to pull any wires from the connector as i pulled the jumper out right?
04.24.2006, 10:12 AM
correct.....
