Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
neweuser
neweuser's Avatar
04.23.2006, 11:44 PM
i may counter them. i like a clean look. still trying to pics on guys. coolhand, i went to rcpics, and somehow cameout livedigital. but not sure how to get them on a link, it's all my login..not sure how to transfer on public yet...but will keep trying!
Stobe slipper tip
rchippie
rchippie's Avatar
Stobe slipper tip - 04.24.2006, 08:31 PM
This is a tip for anyone using the strobe slipper. If you look at your (BLACK) diff ring mounting plate you will notice there is a reasesed section on each ring plate. This allows your bearing to slide back & fourth after some time. Simply put a few shims on each side of your slipper, enough to fill up th reasesed section. This keeps you bearing centered in your slipper & helps keep your slipper from wobbleing. This directions are on the strobe site. I just wanted to make sure everyone knows this tip.
REAL MEN RUN BRUSHLESS
killarevo
05.09.2006, 11:44 AM
what is the strobe site?.......thanks
