Does the strobe come with its own spring/nut or do you use the stock ones? Because I fitted mine with the stock spring, but it doesn't seem to be too tight. The previous owner came up with an overkill solution involving a small spring off a real car and a massive modified nut, but I'm hesitant to fit it due to the extra weight it will add.
