where can I get a 36150, and how much are they? Since a 2250 14 turn is a lower current motor compared to the 2250 13 turn, on 11s lipo, how would its' current draw be compared to the current draw of the 2250 14 turn on 11s lipo? Also the maxamps cells are rated at 12c constant, 16c burst. Would 4000 mah packs still be enough or should I go for 8000 mah packs?
Mike can get the 36150 for you, it is imposible to give absolute numbers for amp draw without testing the system but a higher turn motor on equal voltage will draw fewer amps, I would reccomend the 8000mah if you are set on the maxamps cells
