GriffinRU
05.01.2006, 06:47 PM
Mods to make ESC run Cooler...
Remove silkscreen from power lines on PCB and upgrade with solid copper wire.
3 Runs heat is not an issue but differentials are gone. Front differential - main gear broke, rear diff. satellites gear broke (Milling the rest of aluminum housing :) ). Looking forward for 1/8 diffs bulkheads conversion...
Artur
ID:	1129   Click image for larger version
