RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.01.2005, 12:36 PM
The triple pro can charge up to 10 cells per battery. the amperage it can charge at is dictated by the power supply (if the outlet can deliver the amps, so can the charger). The triple pro can also be used with 120 or 240 volt outlets (so you can use it fine), while the 16x4 is only set up for 120vAC or 12vDC. For the plugs: tell me what plugs (or show me a picture) and I will let you know if I can get them. Most likely I can.
