MetalMan
MetalMan's Avatar
05.14.2006, 11:56 PM
If a motor is past its efficiency range (RPM past 40,000) or has high gearing, it can pull more current than normal. Higher voltage than what the controller is rated for can be a cause of ESC failure, but this wouldn't be an issue for you.
