James
05.22.2006, 08:39 PM
I ordered some stuff and overnight it. 16 tooth pinion, and a 18 tooth pinion, 3 5.5mm connectors, 3 3.5mm connectors, and some other stuff.
I Put the motor in the T2, and i noticed it was really crooked. And it actually looked like the whole trany was crooked. I surned the spur gear, and every few turns there was a tight spot, and some grinding. Im going to take it apart tonight, and check everything out. Has any one had this problem befor?
