RCBoyz had one listed a while back. I tried to order it, but they said they were not in stock. It was quite expensive for a mount like $265 american. included pinion also. ( i don't know why it included a pinion). Well a few months go by, like at least 5, and they call me. They were doing some warehouse cleaning and found one. maybe worth a try.
I just fabbed mine. It is not real pretty but very functional. I just wish I could mill the slots better for motor positioning so I could change pinions easier.
Well I designed up on emachine last night. I emailed it to mike to see what he could do for me. I may start on a set of battery trays to. I can get a mount made up for under 50. It would be hefty 7mm thick. I amy hadd a few holes to something to cut the weight down. I have to see how it goes.
Peace!
Country
Help support the
Rc-Monster Buy here
Yep mike hooked me right up. I did make the hole to small for the bearing on the motor. I had to dremel that out some. Just a small problem. I got the 2250 mounted on it last night. I going to put a brace on it to. The motor is kind of heavy. If things go right I may see about a test run on it. Just have to find an esc for it.
Peace!
Country
Help support the
Rc-Monster Buy here
I need a mount. Its either brushless e-revo or E-savage. And I'm thinking e-savage. but I need a mount that will work with the FLM ext. LCG chassis.
Any ideas?
Mike made mine for me. If you check with him he could probably hook you up with one. Mine is a ext lcg savage flm chassis. It supports the 2250 nicely.
Peace!
Country
Help support the
Rc-Monster Buy here
I would rather not post the price on forum. I do have the efile. It needs a little changing. nothing major though. I can change a few items on it and send it to you. I made mine for a 22 series. so would have to change it for a 19 series
Peace!
Country
Help support the
Rc-Monster Buy here
