cabking
06.08.2006, 04:41 AM
Ive had 5 diff failures, :032: 4 ring gears loosing teeth and 1 bearing collapse causing the ring gear to loose teeth :027: That was probley down to over shimming though.
Compare that to the 18 months I ran the maxx with spyder8's with no problem at all.
Ive now fitted ali cases and housings...................so far so good.
