Is there enough clearence on the front wheel to steer? Cause it don't look like it will clear the shell when you steer.
I dig flame's myself, but if you can't paint it stay with somthing simple like the 1 or 2 straight line's in the center. Or you could always find some inside decal's.
http://www.jackalhobbies.com/
here check this place out. I got some from them the other day.
I love the way the look. I just got to get them on there right.
They go on different than the last ones i did.
Peace!
Country
Help support the
Rc-Monster Buy here
LOL, thought you knew that :). I was just cutting some earlier, and will be cutting more. I do it with my shop-vac secured to my scroll saw, and cut with the shop-vac on so that it will suck up the dust from the garolite and not get into my lungs.
This stuff is rough. I can only go about 10" (254mm) (including turns) before the blade on my scroll saw is too dull to cut with! I've gone through 3 blades already!
dude, you seem to the the most well informed bout this stuff, so i'll ask you...
does G10 come in black? or any other color for that matter?....
I believe the short answer is "yes".
Go to www.mcmaster.com
put "G10" in the search
Click the link for G10 Garolite Sheets
Scroll down on the right to see the colors they have.
Good luck!
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
Ya, it does (as Batfish pointed out). I got my G10 from McMaster, and in the quantity I ordered it only came in the greenish color. If I had ordered a different quantity I could have gotten it in black. From McMaster, you can get black G10 as long as the sheet size is 12 x 12 or larger.
You didn't happen to get those countersunk washers from McMaster, did you? If so, it may be worth it to check the screws for tightness every once in a while, since the washers will bend inwards.
That black looks really good! Can't wait to see the finished product.
