Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
What pinion?
ReDrUm_Racer
What pinion? - 06.09.2006, 06:13 PM
I'm getting the 8xl for a hyper 7 conversion, but I don't know what pinion to get. Any help would be apreciated.
squeeforever
squeeforever's Avatar
06.09.2006, 07:35 PM
Whats the tooth count on the spur and whats the gear ratio on the diffs? Also, how many cells?
ReDrUm_Racer
06.09.2006, 08:01 PM
I don't know, probably stock. It's the pro kit also. I think the rear diffs are stripped, do you know where to get replacements?
squeeforever
06.09.2006, 08:59 PM
Either mike or Towerhobbies will have it probably. I can find out what it came with but how many cells? And what spur? Is the spur steel or plastic?
ReDrUm_Racer
06.09.2006, 09:15 PM
It'll be 12 cells with a steel spur. 42 tooth I believe.
squeeforever
06.09.2006, 09:25 PM
Then a hardened pinion is required. I would say a 13 would be about right.
ReDrUm_Racer
06.09.2006, 09:29 PM
what pitch?
squeeforever
06.09.2006, 09:36 PM
Mod1.
ReDrUm_Racer
06.09.2006, 10:04 PM
Thanks for all your help!
Btw can you get them anywhere for cheaper than $25? That seems waaay too high for a little hunk of steel... I was right at my budget without it and I don't get money very fast these days...
squeeforever
06.09.2006, 10:45 PM
Nope. Mike is pretty much the only person that has them.
ReDrUm_Racer
06.09.2006, 10:57 PM
That sux.. Wont be able to get this thing running for another 2 months!
squeeforever
06.09.2006, 11:16 PM
2 MONTHS!! I'm sure you can sell something or something along those lines...
ReDrUm_Racer
06.09.2006, 11:23 PM
Yeah, I can sell something, but I'd rather not. I get monthly paychecks, and I'll have $300 at the end of this month. That's enough for the brushless setup, battery straps, motor mount, and connector plugs. Then I'll have to wait another month to get my next paycheck to pay for the pinion as well.. ugh...
ReDrUm_Racer
06.14.2006, 12:51 AM
Would this work?
http://www.starluckrc.com/catalog/pr...roducts_id=127
squeeforever
06.14.2006, 01:01 AM
Its not hardened. You have to have hardened pinions. I believe those are actually the same ones Mike has but I'm not sure. If you resort to a standard pinion you need a plastic spur for your center diff.
