I have my 9920 on the way and want to try and understand the wiring of this thing. From the searching Ive done I think I want to wire my batteries in series. Do most wire the Emaxx in series :032: Im using 16 cells with a 9XL.
Is this considered wired in parallel or in series?
This diagram is a little bit different then the one that comes with the External BEC/UBEC, but Im assuming its the way to wire it all together, right :032:
Unless they run lipoly and want to increase runtime. than you use parallel and series. (that's what the P and the S stands for with these cells, for example 5S2P)
A brief note because it may help others. The rx lead (third wire) from the 9920 esc controller plugs ONE specific way into the receiver. I some how plugged mine in backwards and I had fits trying to track down the issue.
Hope this helps someone in the future :dft012:
