Batfish
Batfish's Avatar
06.16.2006, 10:45 PM
Originally Posted by Mike.L
why for a mini-t the truck only takes low Mah. like 1500's and not 3300's know what i mean.
It's a matter of size due to energy density. Both nimh and lipo can fit a fixed amount of power in a fixed size.
Take IB (Intellect Battery) nimh, for instance. The standard sub-c size cell can hold 4200mah of power in that size cylinder. The 2/3A size cell is physically a smaller cylinder that will only hold 1200mah of the same power, simply because you can only fit a certain amount of power within a certain space.
If the Mini-T had the room to mount a sub-c size battery pack, you could definitely use 3300mah cells. It just lacks the physical space for it.
Hope that helps.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
06.17.2006, 12:32 AM
I know it's not the same truck but I've been running an 8cell in my 18T for about 3 months now. Not to say there is not going to be some issues but so far so good. Well except for that noisy diff.:005: Went from 27mph on the 6cell to 32mph on the 8cell.:027:
