neweuser
neweuser's Avatar
06.18.2006, 12:25 PM
That's weird. To enable the bec, i think you need to plug the black jumper in? So it works with this? If you have the bec (black jumper in) enabled, you should not run an rx pack. Or, try to plug the black jumper in, cut the red wire going to your rx, make sure when you do this that the red wire does not touch anything.
