squeeforever
squeeforever's Avatar
06.19.2006, 11:10 PM
No way. First off, the HV-Maxx is a sensored system, so it has less torque. Alot less. Which will mean that the KV will drop drastically under load unlike the sensorless systems. Plus, with the XL motors, you can gear higher to compensate for the low KV. If I'm not mistaken, the XL motors are rated for 1800watts??? The HV is only rated for 375 I believe. The 10XL, on 14 cells would give about 30 min. depending on how you drive. It goes down by about 5 or so minutes per turn.
