And now, after two cans of wd40/trinitybuggy spray here I am. I installed the optional plastic spur, although I oddly needed to use spacers to raise the center diff in order to have clearance for the spur. Other than that the car is almost done, with the except of shocks, battery mount, motor mount etc. I am pleased so far, at least it isn't a heap of clay anymore. The potential battery postitions are in the picture. I will lay them flat if I can, but I am not sure that I have enough room on the motor side. Hopefully the rock guards can take the added stress.
