squeeforever
squeeforever's Avatar
06.24.2006, 12:02 PM
Sounds like they need to redesign there case and maybe add easy mounting for fans :027:
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
06.24.2006, 12:19 PM
squeeforever
Kind of like what the first Novak HV's went through isn't it. They didn't enlarge their heatsinks, which they should have but, the addition a fan gave a higher power rating if I remember correctly.
Never fight an ugly man..... he has nothing to loose
06.24.2006, 02:52 PM
Yeah, I like their cases because they are easy to mount, but after looking at the thickness of the aluminum, it is really too thin and doesn't have enough thermal mass. Plus, the fins that do exist are really too small. According to their specs of being able to run up to 6s/18cells (~22v nominal) and 125A continuous, that is 2750 watts. At 90% controller efficiency, that's still 275 watts being dissipated on the controller, which is WAYY too much for that little heatsink. To be honest, the heat sink needed for that kind of dissipation would be quite large, even with fan cooling. Like I said, adding more thermal mass would be nice to pull the heat from the ESC, and then adding more/taller fins to dissipate the heat. Don't forget to use thermal compoung between the ESC heatsink and whatever you add for efficient thermal conductivity. I actually lightly sanded the back of the ESC to get rid of a lot of the texture and then used thermal epoxy (Arctic Silver) to secure the ESC to the added heatsink.
