Originally Posted by Cartwheels
I'm not sure. I sent them an email yesterday asking that exact thing. It's funny; there is a link for how to order, but it doesn't tell you how to actually order the stuff. I guess either send an email or call them? If/when I get a response, I'll let you know.
As to the fan thing. I agree that sometimes they are necessary like in a PC (although I had an idea where if the CPU was mounted on the reverse side of the motherboard, you could use the whole side/bottom panel for a heatsink). However, in an RC, you have movement which creates airflow. PCs generally don't move around. :dft012: I try to remove as many mechanical parts as possible since things with moving parts are the first things to go bad. Sometimes though, a fan will be necessary and I can accept that as long as it makes sense and is not used to compensate for a bad design or use.
Personally, I think all these ESC heatsinks are too small. But if I look at it from a manufacturers standpoint, I would want to create something small and light that will fit just about everywhere and let the end user decide how to cool it. If they create something with a big enough heatsink, it might reduce their target audience since some may use it in buggies where room is more of a premium - or maybe the dimensions of the bigger unit won't physically fit where the user wants it to go.
I applaud Quark for making a unit where adding a heatsink is possible without having to seriously mod the unit. And doing this really can't go against their warranty as long as the voltage and current limits are met. Nothing was cut or changed, just added to. Thermal epoxy is considered permanent, but it can be removed if you really try.
