I found the specs to the old cells. Maby this helps with the 5C mistery?
Cell Size(milimeters) : 5.0(T)×44.0(W)×140.0(L) ( pack Thickness 30 mm)
Weight: 17.7 oz / 504g (pack weight less wire)
Capacity: 8000 mAh
Voltage : 11.1V
Max Charge Rate: 1C (8A)
Max Burst Discharge Rate: 10C
Safely discharge at 40A up to 48A , with Max burst of 80A (10-15 sec)
