sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
06.25.2006, 10:02 AM
I agree with everyone...you definately need to upgrade the diffs...to atleast the UE 6 spyder, but for a few bucks more you can get the 8 spyder setup, with has the aluminum diff cup over the 6's plastic cup...if these diffs are setup correctly , you will be set..also you need to lose the aluminum bumper mounts..and put stock on there...you need a give point ( or flex point)...at the speeds you want to run..if you hit something....that will transfers the damage elsewhere....bumper mounts are cheap and easy to replace. Also get a steel idler if not a set of the Ultramaxxed tranny gears, which are hard to find, but once in awhile you can find them....
  Send a message via MSN to sjcrss
