Originally Posted by Chaos
I did notice that and I think straps in place of the stock retainers would work, with room to spare on the sides and front, it would mainly just stick up higher. Am I not looking at the dimensions right?
You'd need some very tall straps. 126mm in American/Imperial size is about 5in., and that's the height. There's no way you could effectively keep the pack together and hold it securely.
Originally Posted by squeeforever
What I meant when I said its usually more expensive to run packs in parallel, I ment like to get 2 5S1P packs and wire them in parallel for more mah. It's usually cheaper to just get different packs with a higher mah and put them in series. About the number of cells, its not that theres a problem with 15 cells in 1 pack, its just the weight. I just don't like the added weight as with most people.
It depends where you look. Many times it is actually cheaper to get a pack with cells in parallel than a pack with larger cells. Part of the reason for that is if there are more cells made, then that drives the cost down (that's how it works with everything). As for added weight, there is a little bit because the "pouches" have a larger surface area, but for those like myself, the cost difference outweighs the weight difference. The way I see it, as long as it's lighter/more powerful than NiMh, then it's all good :004:.
