Superbasher
Superbasher's Avatar
07.04.2006, 11:04 AM
speaking of fans, can i just get an old pc fan and hook it up to a 9v battery and use it or do i have to get a bec operated one?
  Send a message via MSN to Superbasher
auto2
07.04.2006, 12:11 PM
if the fan is rated at 12 volts it wont do much at 9 volts.
this is definatlly some kind of heat issue.
I just ran it with a second fan on the caps and it lasted longer before I lost all mid range.
could someone check if all the capacators are the same temp or one is always hotter like mine.
I added a fan pointing at the caps but as soon as a little dirt hit it the blades broke off. guess a computer doesn't have 20 mile an hour dirt in it.LOL!
HotnCold
HotnCold's Avatar
07.04.2006, 12:24 PM
Hey ben - the caps should be about the same temp - they all do the same thing - and you may also be running boat software - but my guess is faulty controller. When Mike gets back from vacation we'll try to get it figured out for you....
Hows that "Hope and Change" working out for Ya???
auto2
07.04.2006, 01:07 PM
Ok sounds like a plan.thanks
