MetalMan
MetalMan's Avatar
07.04.2006, 05:54 PM
If no lights are on and you're charging then that means that the cells are in balance. You can increase the charge rate (you might have to stop the charge and then restart it), and then watch the cells' LEDs. What might have been happening before is that there was a large imbalance with one cell at a high enough voltage (4.30v) that it caused the balancer to stop.
