Batfish
Batfish's Avatar
07.05.2006, 02:10 PM
Originally Posted by BrianG
The Jato is lighter and only 2wd, so probably has a not-so-robust drivetrain. So, I don't want to throw too much power into it and wreck everthing - then again, I DO want insane speeds (~50mph for me is insane) :)
Stock 2-speed with a xl4200 and 3s lipo is right around 50mph with a 21t 32p pinion. I can say that the Jato's drivetrain is pretty strong and not at all loose, but it is all plastic gears so you can only put so much torque through it before they start stripping.
It's also nice that the rear axle diff is a geared diff instead of a ball diff. Ball diffs have a harder time coping with large amounts of torque.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
