RCcarnut
04.15.2005, 07:37 AM
Soldering batteries takes a little practice but is easy once you get the hang of it. I use a 60 watt weller chisel tip for soldering batteries, works really well. You only have to hold it on the battery for a couple seconds to get the solder to melt. If you heat up the cell for too long you will ruin it.
GL
