neweuser
neweuser's Avatar
07.09.2006, 03:10 PM
i used then 1/8th diffs, but i didn't drive it that hard. As with anything, you get what you pay (said this hundred times at least), and for me, i started off with this or that, in the end, wanted more power and speed so ended getting the other. IMO, get the better or best right off the bat because you will in the end anyway! These will work fine, don't recommend to run with the 1/8 diffs either, but if you don't drive real hard....get MIP's though dude!
