Gustav
Gustav's Avatar
07.10.2006, 10:21 AM
if you like them more monster like then i'd stick with your original plan for the chassis,only thing is the length of those big packs may be easier to fit in the G2R.Just see what dimensions you can fit in before you order the packs.
The g-maxx is still very bashable,the carbon g2 is 190grams so the g2r a little more than that,220g maybe?
only dissadvantages of all that Mah is size/weight and charge time.you'd want a charger that could charge them at close to 1c(12 amps for 12Ah).charging at 1c takes 70mins or so including the trickle charge at the end,so at 8 amps it could take a couple of hours.then if you have to charge them one at a time then that's like half the day gone.Just need to find the right charger though.
you might want to consider going up in voltage to get more power and runtime.i get around 25-30 mins from just 3Ah with a 1950/10 on 7s. 6s 8000 would run forever and give more power than the 4s and may be easier/cheaper to find a charger to charge at 1c.
Yes the 2250 is a bit much,it destroys stuff,revo diffs would have to be lucky.
