07.09.2006, 04:44 PM
I would say it's actually okay with a XXX-4. I almost ran my basic XL4200 in my XXX-4, but I ran into a different problem - neither the BK nor the MGM controllers are small enough to mount anywhere in the XXX-4.
I don't know if the smaller quarks will fit, but I imagine the Mtroniks and the new Castle Creations Mamba Max ESC will fit the XXX-4 okay.
Both the older Novak SS controller and the GTB fit okay.
If you do get it in your XXX-4, consider the heavy duty belt upgrade and make sure you keep the belts tight.
Joe
