No brakes?
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
No brakes? - 07.11.2006, 07:59 PM
Why does my brakes always not work when my esc gets a lil hot or even warm?
  Send a message via AIM to nbcaznmaster
Sylvester
Sylvester's Avatar
07.11.2006, 08:23 PM
Is it on a 9918? I think it is the brake fade, you can send your controller to mike so he can replace it.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
MetalMan
MetalMan's Avatar
07.11.2006, 09:01 PM
That's brake fade for sure. BK really had quite a problem with this. The only way to stop it is to keep the controller cooler, but sometimes that's not the easiest/best solution.
nbcaznmaster
07.11.2006, 09:11 PM
is it freee to replace?
07.11.2006, 09:30 PM
A little off topic, but is there an easy way to take off the heatsink (I want to use a bigger one)? It seems like it is held on by either thermal tape or thermal epoxy. I don't to use too much force for fear of ripping off a few FETs.
MetalMan
MetalMan's Avatar
07.12.2006, 09:54 AM
I don't think the heatsink can be taken off easily, unless there's some kind of solvent out there that can dissolve the epoxy without harming any of the compnonents or PCB traces.
