Serum
Serum's Avatar
07.15.2006, 03:23 AM
if you glue the hex inside the wheel with proper glue, and the wheels and the hexes are of decent quality, you can't go wrong.
a pin spinning inside the hex? sounds like you use plastic hexes? use the largest pin as possible is my advice.
If you can't stand it, step up to dace/proline adaptors. (daces are my favorite) the prolines keep getting loose.
HPI got smart and introduced 17mm hexes...
