Maxx 3.3 Steering Blocks
jhautz
jhautz's Avatar
Maxx 3.3 Steering Blocks - 07.19.2006, 01:13 AM
I was experimenting with trying to upgrade my E-maxx to the T-maxx3.3/Revo steering knuckles as a low cost way of beefing them up, and I thought it would also allow me to use the t-maxx/revo stock drive shafts on it to save some weight over the steel CVDs and still have a pretty strong drive line.
Well it didn't work out exactly like I planned...
I did get the 3.3 knuckles on there no problem, but for some reason the stock 3.3 drive shafts don't quite fit in the E-maxx diffs. You can't quite get the 3.3 drive shaft onto the diff drive pin far enough to get the hole for the threaded pin to line up. Its just off by a tiny bit, but enough that you cant get it on unless you elongated the hole in one of the parts. I thought this was weird, why would they make it so close, and not make it actually fit interchangeably? I know the revo diffs are different that the emaxx, but I thought the t-maxx 3.3 was the same.
Anyway... I made it work with some revo CVDs I had. Perfect fit.
The interesting thing that I discovered after I finished the fronts and started looking at it is the 3.3 knuckles extend the width by over 1/2 inch per side. Kind of a cool side effect I wasn't expecting. With my offset wheels I'm now just a little over 18inches wide on my emaxx. Using RPM arms, 3.3 steering knuckles and offset rims.
Not sure if anyone knew about this little upgrade that get you an additional inch of width. Just thought Id post it to see if anyone else has tried this, and if anyone knows of an easy mod to get the stock 3.3 drivshafts to fit the stock Emaxx diffs. Id rather use them than the CVDs to get some weight out.
Heres a pic of the fronts done w/ 3.3 knuckles and the backs with the stock widemax knuckles. (yes I know the toe need to be adjusted). Pretty big difference.
to make it...
or break it...
Silent...But Deadly
