Gustav
Gustav's Avatar
07.29.2006, 12:55 AM
I'm been toying with the idea of using the venturi effect and doing away with fans altogether,i'm trying to figure out what ratio between input and output area of the tube i would need to tripple the air speed.If i could get a 60mph wind blowing over the thing every time it goes 20mph then i don't think there'd be much need for a fan.
Might have to be more like double the air velocity so the OUT isn't too small or the IN too big to be practical.dunno haven't figured it out yet,there's online calculators for it though.
Drag might be a problem though,as might ripping the body clean off at 50mph:005:
The problem with just cutting holes in the body is it opens out after it enters and the air slows down so we're not really getting all that much cooling at these relatively slow speeds,i think maybe what we need is a tube or tubes going to the areas we want cooling.
