MetalMan
MetalMan's Avatar
07.29.2006, 11:38 AM
It depends. There's no need to spend a lot of money (IMO) unless you need the lightest and most powerful battery you can get for that lowest weight. If that's the case, then Thunder Power batteries would be the way to go.
If the capacity is high enough, then you can get away with 8C easily, like I do with my Rustler.
