glassdoctor
TEAM FUSION
glassdoctor's Avatar
07.29.2006, 01:23 PM
Ditto... it's not that the 20C type cells are not better, cause they are. They hold higher voltage under load, etc....
But when you have a 8000mah or bigger battery, even the lower rated cells won't break a sweat too bad in our trucks.
The 20C type batteries are superior, and I would recomend the best you can get for smaller lighter (lower capacity) packs.
But if you can run hard for 30min or more, I wouldn't worry much about the cells ratings.
