Gustav
Gustav's Avatar
07.30.2006, 08:14 PM
Nah didn't work that out,just did it,had these scraps of lexan left over from an undertray i was making for a g-maxx.Didn't take long so i won't cry too much when it gets destroyed:030: ,it's just 1mm lexan superglued together.
07.30.2006, 08:57 PM
Ah, a highly scientific "yeah, that looks about right" procedure? :dft012:
I did a little reading up on the venturi effect and it seems it needs a little more than a funnel. From the materials I read, you need an input funnel with a slope of ~30 degrees, and an output funnel with a slope of ~5 degrees (for least amount of drag). I think you also need a good amount of pressure forcing air into the input because otherwise the air will simply go around the restriction where it is easier to flow (around the hole instead of in it). It might work better at higher speeds since air doesn't have as much of chance to change directions and so is forced into the opening. IMHO, I think the only gain in cooling you will see is from simply having some air coming in directly onto the ESC and not from any venturi effect. Once you test this, try simply making a hole in the windshield with a panel that directs the air directly to the ESC (instead of a tube). I think the effect will be the same or better.
No matter the outcome, good or bad, at least you are trying something different! As for me, I'll just stick to using larger heatsinks. :)
Something else you might want to try; Simply blowing air onto a heatsink is not really air flow; you get eddy currents. A lot of OEM computer makers (Dell, Gateway, HP, etc) sometimes use a ducted system with a fan on the output to pull air through the hot device. For this to work, an air shroud must be fashioned around the heatsink so the air is targeted directly across the fins instead of simply going around them. And since the air is being pulled through (instead of pushed), there is a cleaner flow of air (read: less turbulent).
Good luck! It will be interesting to see how this all works for you!
Gustav
Gustav's Avatar
07.30.2006, 09:29 PM
Yeah very scientific:005:
I agree,just channeling the air across the esc is what i'm thinking of doing.I was just messin' about really,it's kind of the way i think out loud.I think the air will probably manage to 'dodge' the scoop at these low speeds.
There's no direct route for air onto the esc on this truck unless i raise the esc to the level of the windscreen,that might be the best way to go,with a lexan 'box' between the windscreen and the esc.And maybe an exhaust channel straight out the back too.
I've got some heatsinks coming too and some thermal adhesive,i'd like to try to get away without a fan if i can and just use more heatsink and find the best way to channel as much airflow over it,like you say.
