Well, i just measured them, both stock and FLM's..
there is a .16mm difference on both sides. But that might as well be the difference between the gmaxx skid and the GA skid.
so this difference is neglectable.
I think you need to search for your answer. You are sure it are the MIP shafts? and like i said, you can use a spacer between the bearing and the wheelshaft.
