Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
jamesbernatchez
The Brushless Wonder
09.12.2006, 04:12 PM
There's so many different options its very confusing. Im just waiting for Mike to email me back when he returns and hopefully i can carry on with the buildup.
Is my choice of the MaxAmps Lipoly 8000mah 2S2P 7.4V Pack a good pack to use in conjunction with the Neu 1515 and Quark Monster Pro 125B Brushless Sensorless Speed Controller? Will i need to run an external receiver pack?I want something that is going to not stress out the esc and motor. Im really looking for a setup that will stay relativly cool and not overheat. I plan on using a small Novak fan from a GTB ESC for extra cooling on either the esc/motor/or both.
As far as charging the battery.....thats whats making me nervous, hearing about all the possiblities with Lipo's. So with this particular battery...i can charge at up to a max of 8 amps? How would you figure out what to set the threshold voltage at and the cutoff voltage during charging? Does that esc have a cutoff to shut down everything when the voltage gets to a certain level so I wont damage anything? Im only used to Nimh so this is a little new to me.
Would this http://www.rc-monster.com/proddetail...ALANCER&cat=19 help at all after running the pack. After running do i need to discharge the pack after each run and then re charge it or can i just put it back on the charger after each run? Thanks :)
I only have crawlers...finding a brushless project to begin though :)
  Send a message via AIM to jamesbernatchez
