Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.12.2006, 04:35 PM
You must use a lithium-specific charger. There is no "threshold" or any such nickel-cell stuff. :) The lipo chargers know what to do.. they charge to a specific voltage (4.20 volts per cell typically) and hold the voltage steady and slowly drop the amps down to zero.
Yes... you can charge at 1c... which is 8 amps for the 8000mah (8 amp-hour) packs.
Yes... you can put the packs on the charger right after the run... never discharge the lipo before charging under normal operation.
Definitely get up to speed on the lipos.... it's a different ballgame than nimhs.
EDIT: aahhrr beat to the punch again. too many fast guys here :)
jamesbernatchez
The Brushless Wonder
09.12.2006, 04:50 PM
So are you saying use an Astroflight 109(i think that was it) instead of my ICE?
I only have crawlers...finding a brushless project to begin though :)
  Send a message via AIM to jamesbernatchez
squeeforever
squeeforever's Avatar
09.12.2006, 05:12 PM
I wouldn't use the Astroflight. It's not a CC/CV charger and doesn't work well with most balancers. Get something like the E-station 701 or even a 301. I think the 301 is the same thing as a Multiplex charge, like alot of other chargers. The Ice should work though...
natrix
09.12.2006, 05:31 PM
Sorry to hijack again, but for the noobs, what is a CC/CV charger?
glassdoctor
TEAM FUSION
09.12.2006, 06:04 PM
ICE is fine... it is a true "lithium" charger. I meant you can't just use any old battery charger.
CC/CV is "constant current/constant voltage" and it describes how it charges the battery.
CC stage gets the battery to 4.2v
CV tops off the charge by holding it steady at 4.2 until the battery can't take it any more.
The current will slowly drop to zero once the charger hits 4.2 and switches to CV mode. . Once the current drops off a lot, like below 1 amp... there isn't much "charge" put into the battery... just a few mah.
cabking
09.12.2006, 06:48 PM
Originally Posted by Serum
[url=http://rc.stuurmijmail.nl/HB%20lightning%20make%20over/index.html
here[/url] is my attempt of making one brushless. I would do it different now.
With a lay-down motor-mount. (so the motor sits next to the diff, instead of above.
Hey Serum with a couple of Mike's sinks and a bit of welding you can have one that you could beat a whale to death with :032:
squeeforever
09.12.2006, 07:11 PM
Holy hell...That thing is nice! Besides that, I'm sure you won't have a problem with over heating...
jamesbernatchez
09.12.2006, 08:10 PM
Yeah i just read through the ICE's manual...its should actually be a pretty good lipo charger.
Now i just need a motor mount to actually continue with this project. I found a member on RCCA that has made a machined aluminum mount that im trying to see if he can make me one. And i also emailed Mike about it but i will have to wait for him to return before i get an answer. Until then there isnt too much i can do to the truggy except to sit and wait.
Serum
Serum's Avatar
09.13.2006, 01:15 AM
Cool(ing) thing Cab!
TIG welded?
jamesbernatchez
09.13.2006, 11:48 AM
That motor mount is crazy :eek: Looks very strong.....
cabking
09.13.2006, 05:19 PM
James, The waiting is something I never get used too with this hobby :027:
I'm sure Mike will sort something for you though.
Serum , Na its Oxy'/'cetelene, with a fine tip and a VERY practiced hand.
Its abit heavier than I would have liked but mabye a few hole here and there will sort that. Still it wont be bending anytime soon
