MetalMan
MetalMan's Avatar
09.13.2006, 12:11 AM
Dimension Engineering makes a LVC called CellShield that monitors the individual cells in packs. You could use the series adapter I drew up to hook the balance connectors from the two 3s packs together so that all 6 cells in series could be monitored by the LVC. They might be working on a car version for it, but I haven't gotten a definitive answer from them (I've offered to beta test the car version if they were to make it). Check here:
http://www.rcgroups.com/forums/showthread.php?t=566012 (I'm TMetalMan)
http://www.dimensionengineering.com/CellShield.htm
