09.15.2006, 12:13 AM
Originally Posted by Finnster
The only heat concern I am having is from teh motor (8xl.) A neu/ lmt will run cooler and could poten be geared for a bit more speed. Overall I am very pleased with my setup.
Finnster, I am curious as to what temps you are getting with the 8XL. When I used it in my Revo, it ran about in the 130-140 range. On 14 cells it ran great, even on my heavy truck. If you go higher on the cells, you start hitting the high end of 40krpm and would heat up more.
