Originally Posted by Re~Mix
You're playing around with the relatively low end motors, which are kind of apples to oranges as long as the stay cool. If you want to try something different, grab a neu. I'm sure that would be a rocket.
Correct me if I'm wrong, but the Mamba Max series motors are 540 designed, so the 380 will spool up faster, and if its in a stadium truck that isn't running moabs it should be better. I think mamba motors are of a little nicer quality though. Why not try a lehner basic, very light, small, and efficient.
I would not do the 6t on 3s, simply a waste. Maybe a 7 or 8t.
I don't think it is fair to call the Mamba Max motors low-end.
The rotors in these motors aren't actually full 540 size, but if I remember correctly SpEEdyBL pointed out that it's between a 400 and 540 size. I doubt that the difference between spool up times between a 400 size and a 540 size rotor would be noticeable in a stadium truck unless you're a pro racer that can
feel that sort of thing.
SH Z-Car, Custom Crawler, 8s Savage,
12s XTM XLB 1/7 buggy,
4wd 4-link rear/IFS Pro4 truck,
Custom Hyper 10 Short Course,
Belt-Drive Mammoth ST 1/8 truggy, 4s 17.5 MM Pro HPI Blitz
