05.11.2005, 01:58 AM
The Wabash 23mm wheels are great for tight tracks. RD is comming out with aluminum axle carriers and a 23mm hex adapter solution that looks impressive.
I am using 60 weight oil with Gold springs up front and the black springs on the rear (2 steps higher than stock). This setup has been working quite well for me. The truck is balanced nicely front to back but the weight is a little off center to the right rear because of the placing of the batteries. I initially thought this would cause performance problems but the truck handles very well and I have been very happy with the results. I will use a similar battery mount when I get my Kokam Lipo's. The Lipo weight should be more balanced due to the weight decrease and placement.
The thingy zipped tied to the front body mount is a small piece of lexan used to mount a transponder. The transponder is used in races to count the laps of the truck.
This truck keeps up with the big block nitro's .21+ and has an edge on the stock nitro Revo's.
I'd be interested to see your one-way and center dog-bone setup.
Ha Ha
