neweuser
neweuser's Avatar
10.02.2006, 02:54 PM
Originally Posted by Klausen
I have just mounted my G3 race suspension, but I am not sure that the pivots are screwed enough or too much into the a-arms.
Originally Posted by go4gold
If you are running RPM arms then you are only supposed to thread the balls
he has the G3 suspension. And to clarify, it will be about almost all the way in for the bottom pillows, barely any threads showing, and the top maybe around one or two threads showing. But to stop binding, you need to adjust accordingly. Make sure that when your a-arms all all the way extended with NO pressure on them, the the bone part of the cvd is about 1-2 mm from hiting the back of the cup.
