10.02.2006, 08:34 PM
crazyjr: Yeah, there does seem to be a few issues with the Quark. However, if no one ever got on the bandwagon to find these issues, no one would ever know. :) I still love mine and it works great. Even though people have been having good luck with the MM, I feel a little more secure in the fact that there are quite a few more FETs on the Quark to share the current load. Would I buy it again? Maybe not now that I know how the MM works, especially for the price.
smhertzog: Yeah, the manual does read that way. It is confusing. On one hand it does say that changing from Lipo manual (and then setting the manual level) to Lipo automatic won't change the manual setting. It does not explicitly say anything about what happens when switching to NiMH though. Logic would dictate that any NiMH setting would disregard the manual cutoff settings, but you never know. So, to be sure, I'd set the manual cutoff to 2.2v. For 12 cells, the ESC should "see" that as 4s lipo. At 2.2v/cell, it will cut off at 8.8v (2.2 X 4), which is probably good for 12 NiMH cells. You'll surely see performance loss long before you get to that level. For 14 cells, it might see that as 5s, and cut off at 11v (2.2 X 5). See how that runs. If all looks good, you might then try setting the battery type to NiMH normal/high and try it again.
