10.06.2006, 08:08 PM
Pure water has around 15k ohms of resistance per inch, less in normal, mineral (especially salt) laden water. Water doesn't usually short out electrical connections unless it has very high salt/mineral content. It's usually the resulting corrosion that does more damage than it simply getting wet. Corrosion creates bad connections, then arcing, heat, and so on.
If a circuit "blows" because it got wet, it's most likely caused by the low voltage section of the circuit where the resistors and caps have larger values, which changes the signals and causes the output to do strange things.
Since snow, mixed with whatever is on the ground, can have high mineral content, it might cause substantial oxidation/corrosion in things like the motor, wiring, battery contacts, causing them to go bad.
jhautz
jhautz's Avatar
10.07.2006, 02:20 AM
So what you are saying is use a motor. and electronics I dont care about because chances are they will get ruined even if they dont short right away.
Just using the old 9L is sounding better and better all the time. :)
to make it...
or break it...
Silent...But Deadly
