10.07.2006, 09:08 PM
I have noticed that as well. I put spacers, but then there apparently wasnt enough threads into the bulkheads (use a longer screw if you keep your spacer) as one of my screws ripped out. I am going to tweak with the rocker mounts to try to get it to clear without raising the shock mount at all, or at least just very little. I had mine raised about 3mm.
