just want to point out that as far as i know mamba max controllers dont have a problem with 4 pole motors.
Glassdoctor was running a neu motor on one in his 1/8th buggy conversion and he says it works great i am not sure what settings he uses but i suspect that you need to set the timing settings higher as you normally do.
