monel_funkawitz
User replaceable parts were meant to be broken.
monel_funkawitz's Avatar
10.12.2006, 08:54 PM
If you have enough patience, you will get it.
Aluminum is some proingy stuff anyway. If you get 100% mesh, it will change under heavy load anyway.
If it makes you feel better, I have a pulling tractor that I can slip a sheet of paper under half a pinion tooth. Its that far out of whack. If I go for more mesh, it turns into a gear muncher.
