10.19.2006, 03:58 PM
Originally Posted by TypeR #126
As far as the rear brace, I've been tossing around a couple ideas. The simplest being a pedestal that could bolt to the rear of base that would be curved with the approxiamate diameter of the motor can, but not touching. And then use some kind of shock absorbing material to go in between, that would compress to the final shape.
The other idea is more complicated, and would make the use of a heatsink problematic, but would be like the Fine Designe motor mount that has a rear clamp to completely support the rear of the can.
Looks like we have a similar idea for the rear motor support. The pedestal idea may be simple, but simple is usually the better (and cheaper) route. Although instead of seperate pieces, just make the whole thing out of a firm rubber and wedge it in there. That should be even cheaper and simpler. It also would work with the slightly larger motors (Neu) since rubber does have some flex.
The heatsink clamp is interesting as well. To get around the issue of using the RCM heatsink, just machine it such that part of the clamp replaces the RCM heatsink bar.
